Marque, don't know about the full-length mirror but about exporting from Bryce it's tricky. Seems that bryce will export only certain objects ( the criteria of that being something I haven't found out yet). Here's the procedure: If an object in bryce has the E (edit) box when you select it then click on it and when the edit box opens up hit Ctl+D on your keypad and a save option should come up. Scroll down to save as .obj (probably best cause you can uvmap). Unfortunately on most cool things I don't get that little darn E box :) I guess it might have something to do with groups, I've tried grouping everything first but gave up. If you discover something new please do let me know!
Has anyone done a full-length mirror that moves? Also, is it possible to use stuff from Bryce in Poser? I see a lot of cool things for Bryce, is it possible to bring them into Bryce and then export them as an obj or something so that Poser will recognize them? Or am I stuck using them only in Bryce? Thanks, Marque
