Fri, Feb 7, 7:33 AM CST
Subject: Bryce 5 memory
Rendermom ( ) posted Thu, 15 January 2004 at 8:15 PM · edited Fri, 31 January 2025 at 4:10 AM
Does anyone know if it is possible to allocate more memory
to Bryce 5, and if so, how is it done????????????
woodhurst ( ) posted Thu, 15 January 2004 at 9:30 PM
As far as I know, if you have multiple machines, and a network, you can use "Bryce Lightning" that should be on the disk, I think it distributes the render to the different computers so you can get extremley fast render times.
danamo ( ) posted Thu, 15 January 2004 at 10:17 PM
Are you on a Mac, or a PC?
Gog ( ) posted Fri, 16 January 2004 at 5:39 AM
And which OS?
Toolset: Blender, GIMP, Indigo Render, LuxRender, TopMod, Knotplot, Ivy Gen, Plant Studio.
shadowdragonlord ( ) posted Fri, 16 January 2004 at 1:46 PM
The very BEST way to allocate more memory to Bryce is to go buy more memory. I have a scene that is only slightly above 150 MB, file size, but it will not render until I get 1 GB of RAM. I've had scenes that were larger and rendered them fine with 512, but this particular scene has many, many .obj imports and .3ds imports, and crashes if it's opened for more than a few minutes.... If you're using Windows, you can change the Virtual Memory settings to get a little bit of headroom. I set mine to a minimum of 512 MB, and a Maximum of 1 GB, which seems to be enough for Bryce, usually...
