Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 16 10:02 pm)
I personally prefer INJ/REM and MAT files, but then I'm running P5 (giving me the flexibility of sub-directories) and I'm on a fast machine. Looks good, by the way.
"you are terrifying
and strange and beautiful
something not everyone knows how to love." - Warsan
Shire
sebastel, unfortunately these morphs are a bit complex and magnets are not exact enough. I made the morphs with C4D and the Morphloader plugin. You're right xantor, but if you want to have 10 or more of these columns in a hall, you may be running into troubles. That's what I was afraid of. karen, INJ/REM files seemed to me the best idea until yet, but during this discussion, I had a forth idea and I'll give it a try. I would like to reroute the discussion to the original thread (Just follow the link). Thanks for your help and nice comments - Walter
Attached Link: http://www.renderosity.com/messages.ez?ForumID=12413&Form.ShowMessage=1618955
I need advice on how to set up flexible elements from experienced Poser users.I made an item with about 15 morphs to make it very versatile. Technically I made a *.cr2 file with external geometry to be able to apply different materials by simply using MAT files.
The *.obj has a reasonable size (about 500kByte), but the *.cr2 got quite heavy (4MByte) because of the morphs.
As this is a building part, it is intended to be used several times in a scene, so I'm searching for a solution.
I see 3 options up till yet:
Any other suggestions?
You can see more details on the provided link. As this question concerns a product I make, I cannot post this here, but the response in the Product Showcase Forum was quite poor. I think most of the experts are here.
Please give your comment and tell me your view on things
