Forum Moderators: Staff
Assuming you are using Poser 4 try this: With Poser not not running, in Windows explorer navigate to the .RuntimePREFS folder and rename the file 'preferredState.pz3' to 'preferredState.OLD'. Open Poser, it should open in the default configuration. Setup the Poser interface the way you want it then save a UI dot. In Windows explorer navigate to the .RuntimeDOTS folder and make the file 'uiDot_1_.ui2' (where "" is a screen resolution) read only so that you can always restor to this UI if things mess up. The problem with the window can happen if you chainge your screen resolution, but it seems that sometimes it can happen even if you don't.
Suddenly the posing window went stuck to the upper left corner in the Poser (ProPack) workspace. It's immediately below the menu bar and so there's no way to move it from that place (usually You have to grab the document name to do it...). I returned to factory state, but that didn't affect the window position (the same happened loading previously saved .pz3 files). Could anyone help? Thanks, Alberto.
