Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 22 4:04 pm)
Things to check 1. Do you have Victoria 3 and her sr1 update installed? 2. Do you have the face morph pack installed? If you do, then load v3 into your scene and click on her head so that you can see all the dials for her face. Go to the pose library, select the folder with the head morph in that you want to apply and apply it. You should see a new dial with the name of the morph on it in the list of dials for V3s head. Turn the dial, the more you turn it, the more extreme the effect. That is how they work. Is this what you are doing? As to your hair problem, could you be a little more specific? What is the problem you are having with it, and which hair model are you trying to use? Hope that helps Shanna :-)
Sekopasa, With Poser 5 I have found that if you have the Head selected when you inject the optional V3 morphs from the Pose folder, they don't show up at first in the Head's parameter dials. You have to select some other body part and then select the head to see the newly injected dials. Same thing for body morphs. The hair in the Poser 5 Hair / Dynamic Hair folder will not work with Victoria, it is designed for Judy. Perhaps that is your problem? Cheers, Poseur
I dont know why does it happens but as i said i can't aplly the face morphs, maybe it is because of poser 5, and there is problems when i try to add hair.
