Thu, Jan 9, 5:38 PM CST
Subject: Fed-Up and Frustrated with Poser to Bryce Hair!
mmajor ( ) posted Sun, 18 January 2004 at 8:59 PM ยท edited Thu, 25 July 2024 at 3:05 AM
I'm soo close, but yet so far away. Many of you have helped with my Poser/Bryce education. However, I've hit a wall. I've created some wonderful landscapes in Bryce, and have created some wonderful poses for Mike M2. But Once I import my Mike m2 or horses with manes, I get the old helmet head of hair. I've tried every tutorial I can find, and I'm not getting any closer. I'm going mad. Does any one have any solutions, suggestions, special tutorials that may help? Please... Thanks, mmajor
Ajax ( ) posted Sun, 18 January 2004 at 9:29 PM
It's all in the transparency. Depending on how you imported to Bryce, you probably have the transparency map already loaded, but you need the right settings in the materials to make it look right. I remeber you have to have "blend transparency" chosen, but I'm no expert in Bryce. Someone who uses it more can probably tell you exactly what you have to click to get the transparency working right.
Bubba ( ) posted Sun, 18 January 2004 at 10:51 PM
Simple to do. Example using Kyokohair MK Step one: load your hair texture ( shown settings are just for example you can adjust to your liking). Step two: click a blue dot in the tranparecy field as indicated (this will bring up a new window to load your hair transparency into). Step 3: click the triangle and make sure that the "Blend Transparency" dialog is checked. (the other fields you can play around with to see what best suits your image. Thats really all that needs to be done.
Phantast ( ) posted Mon, 19 January 2004 at 5:23 AM
Just to stress that you need to make sure the transparency is loaded into the alpha channel (see how it appears in all three boxes above?). You can do this by copying it from the colour channel in the deep texture editor. Also, if you aren't using a bump you can put the transparency in the same channel as the texture, rather than use two channels as shown here.
