Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 13 7:03 am)
There is a python script that will compress your runtime too. It is quite handy. It shold be in your python directory. You can tell it to compress the files and delete the uncompressed ones (or keep them but I don't know why you would want to). I did it on my ProPack installation and it saved me about a gig of space. It will compress .cr2 to .crz, .pp2 to .ppz etc... You don't lose anything. You just gain space. The one caviot is that compressed files show up as unlegible information in a text editor. SO... If you want to edit say... a .cr2 from a figure you just need to save it into your library with compression turned off in your prefs. Then it saves the figure as a .cr2 and can be edited. Cheers, Joe
how can i compress files manually into this "pzz" format ? just zip he file and rename it from .zip to pzz (such as winamp skins that become .wsz ?" soudns too simple, and i cannot use python (poser 4 non propack) maybe such old version cannot handle the zip compression you are talkin about. But yes it would be a true gift if it could work.. just tell me
Riddokun, the poser files arent compressed with zip, they are compressed with g-zip a different program despite the name. If you search for g-zip on the internet there is a free copy you can download though it is only a dos program. If you download g-zip then you can make zip load and decompress g-gzip files including the pzz ones.
Hello, I'm trying to cut down some of the wasted space (well, wasted might be the wrong term :-) and wondered if converting alot of pz3 files that just sit around in my figures folder to pzz and compressing them. I won't lose anything this way will I? I have noticed the file size is considerably less.... Greymeister
