Thu, Nov 14, 9:01 PM CST
Forum Moderators: Staff
Poser Technical F.A.Q (Last Updated: 2024 Nov 13 12:50 am)
Subject: Sketch designer help
trew ( ) posted Thu, 31 August 2000 at 12:07 AM · edited Fri, 09 August 2024 at 11:22 AM
Is there a way to render a poser animation in sketch designer format?
siva ( ) posted Mon, 04 September 2000 at 12:17 AM
Trew, Go to the Animation Menu; click on Make Movie. Under Quality choose Current Sketch Settings. It will render the movie with the settings you set up when you last used the Sketch Designer under the Window Menu. Hope this helps--it offers all kind of interesting animating possibilities. siva
trew ( ) posted Mon, 04 September 2000 at 10:21 PM
Thanx for the info Siva
