I have 50G left on my HD & sometimes still get that message trying to render 1157 & less. And yes, I do defrag 1x a week. Only solution that I've come across is to reboot & try again & that has always worked for me. I'm not sure what causes it, but that's only I way I can get around it. Also I have nothing running in the background other than my broadband connection.
Actually by raising your VM to 2 gigs, or higher (depending on the size of your HD), this problem should be solved, for example I have a 2.8 Gig machine, with 1 Meg of memory, a 60 Gig HD and a second 120 gig HD, I can take about 2 Gigs per drive, that gives me 5 Gigs of memory to play with. With that much memory I sholud be able to render anything in Poser with no problems.
Ask me a question, and I'll give you an answer.
I have this reoccuring problem when i try to render sometimes where I get a popup message that says Insufficient Disk space to render at current resolution. I'm running Poser 4 with all the updated on a PC. I usually render everything at 3000 px 100 dpi. I have 10 gigs of free space on my drive, but still get the message, even when I lower the size to 2000 px. Can anyone help me with this? PLEASE?
