Sun, Jan 19, 6:21 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 19 5:17 am)
Subject: help please with Jessica!
DarkElegance ( ) posted Sat, 24 January 2004 at 3:10 PM ยท edited Sun, 19 January 2025 at 3:12 AM
I am going nuts! I have been working on a piece for sometime now. finally got the M3 to sit JUSSSSSSSST the way I wanted him to. and went to bring in V3...wanted to use the jessica dress and morph from PhilC. went to the !V3 all morph setting in pose and nope jessica is not in there... so went tried to reinstall. finally just moved the pz2 over to the folder..ok. went and hit the inject...and the only thing that happened to V3 was the blue gloves appeared other then that nothing. I figure there must be some problem probably cross talk. I open new window load JUST V3....make sure all her morphs are injected...go ...hit the jessica injections ....and again NOTHING but the Blue gloves appear on V3. {note the dress was NOT loaded} what am I doing wrong? how can I get the morph to make v3 look great with that shape? and also how on earth do I stop cross talk?
https://www.darkelegance.co.uk/
Commission Closed till 2025
DarkElegance ( ) posted Sat, 24 January 2004 at 3:11 PM
OH! ack poser pro pack is what I am using.not poser 5
Tashar59 ( ) posted Sat, 24 January 2004 at 3:29 PM
Attached Link: http://www.nerd3d.com
If you get Nerd's cross talk fix, at his site, that will get rid of that issue. Load it first in new scene, then your figure, then the fix again, then the other figure. I've had quite a few V3's in one scene this way. As for your other question, I can't help you on that one.
PhilC ( ) posted Sat, 24 January 2004 at 5:10 PM
Can you double check that all the files are in the correct folders. Full details are in the readme_V3JessicaDress.htm file. Then place V3 into a brand spanking new scene and she should perform as required ;)
DarkElegance ( ) posted Sat, 24 January 2004 at 6:39 PM
I did make sure I have tried to reinstall her a few times. I know
it has to be something I am doing wrong as I have seen pictures
with the morph used. I just dont know how to get them to work. The
deltas are in the !DAZ folder where the read me said they should be
but they dont show up in the !V3 all morph inj folder until I put
the pz2 file and all actually in that folder in the pose folder.
she looks wonderful and is perfect but I cant seem to get vicky to
morph to her>.
Crasher ( ) posted Sat, 24 January 2004 at 7:33 PM
Jessica worked fine for me when I tried her. The only difference I can see in mine than what you've posted is that first, the Jessica morph was in the !V3-Full Body Morph pose folder. Not sure if that has anything to do with it or not, but it's not in the 'All Morphs' folder. Second, make sure the top dial, which -should- be the Jessica dial is set to 1.000. That's how mine is. Not sure if it makes a difference. :)
DarkElegance ( ) posted Sat, 24 January 2004 at 9:01 PM
~beats her head against the desk~ I knew it was me doing something wrong. I apologize I got it to work~sighs~ I need to get sleep going wtih out is not good
hauksdottir ( ) posted Sun, 25 January 2004 at 4:26 AM
Going without sleep is very, very bad. The body never recovers (it isn't like a bank account where you can restore funds or even add extra). Too many things are being fixed, sorted, and patched while we are sleeping.
