Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 21 11:11 pm)
Attached Link: Baument.com
http://www.baument.com Updated the downloads page with 'Bulk Head Kit'. This is one I've been saving for some time. There are several models in the set including a wall panel, door panel, corner and a floor panel. The floor panel makes a super grate model all by itself. The wall sections have curved pieces at the top and bottom which are intended to be lights. Try adjusting the transparency of these and placing a soft light behind them. By linking the panels end to end one can create long corridors. If you want a two sided (completly closed) hallway, construct one side and then clone it, turn it 180 degrees and place it. If you want to speed your render times and reduce your file size, use your own flat floor panels. The included floor panels are the largest models in the set and they will add much to your overhead when you have tons of them. Enjoy this one, I know I have. Don't forget to try a nice rusty texture on the wall panels for that 'alien space ship' look. If you've got a minute to spare, swing by the products page and have a look at our commercial offerings. Perhaps you'll find something there you can use also.
