Mon, Feb 10, 4:18 PM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara F.A.Q (Last Updated: 2025 Feb 10 2:42 pm)
Carrara Free Stuff here.
Subject: Circular Wave not working?
siva ( ) posted Thu, 07 September 2000 at 5:35 PM · edited Wed, 05 February 2025 at 1:06 PM
Has anyone tried to animate a plane with the circular wave modifier? I cannot get it to work in the z axis at all like the manual shows. It seems to work in the x and y axis(es). thanks, siva
willf ( ) posted Thu, 07 September 2000 at 11:03 PM
I havn't looked at the manual but the circular wave seems to work in all the axis. Didn't animate it either but that shouldn't (ehem) make any difference. If you'r stuck (and your object can be rotated to a different plane with little problem) then try this: First, rotate your object so that the plane you want to deforme is in the plane that is working. Then group your object to reset the bounding box and hot point to 0,0,0 and apply your deformation. Then rotate the object back to its proper position. The deformer works in relation to the bounding box coordinants and not the object. This means that you can group the object again & again and apply many deformers to the same piece, providing you have a fast machine and some patience.
MarkBremmer ( ) posted Fri, 08 September 2000 at 8:36 AM
I couldn't get it to work on a standard plane either. However, I created a cube with no thickness to it and it worked fine.
willf ( ) posted Fri, 08 September 2000 at 11:07 AM
Whoops! Good thing Mark replied also. I forgot to mention taht I had used a cube too.
siva ( ) posted Fri, 08 September 2000 at 6:30 PM
thanks guys. It also worked for me with a squashed cube. Strange how all the other wave options work with a plane tho.
