Attached Link: http://www.keindesign.de/stefan/poser/firefaq.html#8
Try the thing at the link, that will probably fix the problem, it is a small poser 5 bug.Here's a screen cap of my material settings for the sky dome. See if yours are the same.
I've noticed that sometimes, P5 screws up the material settings on items that were designed for P4. I think it has something to do with the way P4 uses 100 to mean P5's 1.
I have some objects that refuse to render as anything but solid black in Poser 5 using either the Firefly renderer or the Poser 4 renderer. Both of these objects look fine when viewed as texture-shaded in the Document Window, although I had to change the ambient color to gray on one of them to see any of the texture. Has anyone else experienced this? Is there an easy fix? Gromit
