You are getting close to the face. The hair has blonde roots and is more organge than red (it would make a real transparency challenge by itself). Milla is a model and her stats are claimed to be : Height: 5'9 or 174 cm Bust-Waist-Hips: 34-24-34 (in) or 86-61-86 (cm) Eyes: Green --- so she should be thinner and less endowed. Keep up the good work though .. an interesting project. Is anyone for making some of the other figures (like the Diva)?
Thanks for the stats they will help get the proportions right, I was just working from the VHS and stills taken from same. As for other figures, I hope to work on a corbin Dallas after leeloo is finished. Hairwise I havent really touched her yet, going to add some modelled fringe pieces then work on a trans map. Only scaled a default hairpiece to roughly the right length and gave it an orangey red colour.
Thanks for the input guys, funny you should mention the catsuit, was playing around with that to see whether it woud work and it does, so now all i leave is the characters belt from trousers(rest I will try non visable) and the skin tight catsuit. Thanks for the tip on the hair, I will take a look at it and see how it goes. Update on the boots is that I think I will be making some modifications geometry wise to a pair I downloaded so before I can post the figure I will just have to get permission to post the modified boots from the original creator.
