You cannot render as a "tiff", except if you render to disk. Otherwise, you only can "render". When the render is finished, you can then save your image as a tiff or bmp or whatever. So, you are maybe doing something wrong. When you have finished your scene, select PICTURE--->RENDER OPTIONS from the top menu and select how and where you want to render. Click OK and your imgage will render. When render is finished, click the small icon (save displayed picture), this saves your image. Have a look in the Vue user guide, it is well explained there. What Vue version are you using? Vue 4 what? 1,12,03,05,2?
I have tried to render a simple scene in Vue4. Nothing is happeneing....usually it tells me it is rendering. I went to the manual and tried several different settings as described...still nothing.All updates installed. I have a Pentium4 512 ram 80 gig hard drive.
