Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 02 7:25 pm)
did you uset a mat or did you made own setting for the cloth? did you set good your rendering option, because if you don't check the box it will render as a bump map, you can controle the hair grow with the value of the displacement map in the material room.
_________________________________________________________
"Surrender to what it is - Let go of what was - Have faith in what will be "
if they created it so they know better why this don't work correct, I don't own this can't help you, thry out our setting we used in the past days in this forum it works for sure.
