Mon, Dec 2, 9:47 PM CST
Subject: texture map ? not fitting
estherau ( ) posted Sat, 07 February 2004 at 8:22 AM · edited Sun, 01 December 2024 at 6:54 AM
I don't understand this. I applied the ectasy texture (from the merchant resource here at MP) to my V3 and I made the nipples pinker, but when I applied the texture to the area called nipples the pinkness was on the breast below the nipples. So then I rezized the texture to exactly the same size as one designed for V3 overlying one on top of the other, and resaved my jpg and reapplied it, and it still had the pink in the wrong place. Any ideas what I might be doing wrong? Love esther
MY ONLINE COMIC IS NOW LIVE
MysticMind ( ) posted Sat, 07 February 2004 at 8:34 AM
It soulds like the nipples on the texture do not fall in the same place as the material that is called "nipples". A lot of people design textures for cases when the model is all white. The only ways you can get around this are to either move the nipples on the texture, or do a hue adjust on the texture until you get the color you want. Just make a selection around each nipple, feather it very slightly so it blends into the surrounding area, and then adjust the hue. That should do it.
soulds should be sounds. DANG I wish there was an edit button! LOL
estherau ( ) posted Sat, 07 February 2004 at 3:52 PM
But the nipples seem to fit on the same spot as one of the daz standard textures when I supperimposed them together. It's weird. Still playing, I'll let you know. Love esther
estherau ( ) posted Sat, 07 February 2004 at 4:53 PM
the little tiny area over the centre of the nipples on the texture map is actually a huge area of breast on the figure, especially the bit under the nipples, so if I keep the coloured part really small over the centre it seems to work okay I think. Just trying another test render now. Love esther
estherau ( ) posted Sat, 07 February 2004 at 4:54 PM
Yep - that worked!
