Forum Moderators: Staff
MarketPlace Showcase F.A.Q (Last Updated: 2025 Feb 16 8:12 am)
Seam Guides sounds like a good idea and could be made anytime for this figure then. Evangeline type add on package (tex and props) for Catsuit is in planning stages and I am hoping to release one within a week from the the day the catsuit is released. I am already discussing this with The3dZone. thank you marty
ABOUT TWO LAST PICTURES I POSTED I picked this particular texture, in the pictures above, because it would show every flaw - even more so than a checker patern. It is like putting the uvmap under a microscope. You will notice some slight distortions or lines. There are two lines on either side of the thigh and one line in the junction of the arm and shoulder. Very slight though I feel. These are the final details being tweeked out of the map. Other than that, its done! I am doing a similar map for the trims on a seperate map. It will work the same way so that one flat texture will flow evenly over all the trims. I have every intention on getting this product submitted by this friday. Thank you marty
Oh, I am hiding the seams, lol. Right where they should be. Seams run under the arms, inside the legs, and down one side of the body. The map is set up into three main parts - these parts were not intended to be a perfect match between seams when using a texture similar to the one above. These divisions were put along natural clothing seams. -------------- 1)Body - this is set up to be textured like a leotard. 2)Legs - here the texture flows down the legs like pantyhose worn underneith the leotard. 3)Arms - the seam begins where it would if the sleaves were naturally sown on ------------- Like I said there will be a seperate map for the trims thank you marty
Thats exactly right Senshi, I have alreay tried making it into pantyhose then placing my MiniDress over top. Worked out great! She looked very sexy! I will be putting in Pantyhose MATs in the package as well. What you can do with this outfit is really in the eye of the beholder. What you can do with it with MATS, textures, transmaps, etc is limitless. This will be one the most widely used clothing packages for AnimeDoll, this is why I am working so hard to make it as close to perfect as possible. thank you marty
thanks for asking Senshi, The Main Map is the the main catsuit. That is a catsuit in general terms. Look up at Responce Number 9, thats what it is. The Trim Map consists of trims that work independent of the body of the catsuit and can be turned off and on at will. Responce Number 16 shows all the trims turned on. This is, incase you havn't guessed, much more than your average catsuit. There will be a few more surprises about the package that I havn't revealed yet. Stay tooned:) marty
Oh, I just wanted to say that I tweeked uvmaps and virtually removed all those distortions that I complained about in an earlier responce, those examples of uvmaps (responce number 56 and 57)will look much better now. The destortions like I said are virtually gone and I have evened out the flow of the texture over the entire figure more evenly than previously shown. At the time I am writing this responce, I am working on the Joint Controlled Morphs, I am placing these where needed to prevent poke thrus during most extreem posing. I hope to have it finished today and be working on the adding Morph Injection version of Khrys's full body morphs tomorrow. The3dZone and I are putting our heads together on a couple suprises for the package. These suprises will be anounced at the last minute. Stay tooned! marty
Shame about Khrys's stuff not being in the set. I hear he did really nice things with Anime Doll. ^^ Hopefully it won't be too long for an add-on. Meanwhile, the suit should fit my v4 dolls very nicely. I haven't been able to check it yet ^^ but can't wait to get this thing from the store. Looks good on Maya Doll there. I hear you say most pokethrus, anything we can expect to really stand out in the way of posing extremes? You got the buttocks thing to work?
I am sad myself about khrys's maps not being in the base package, but on the pluss side, it will cost less than it would if it had. I am not sure what you mean by buttocks thing to work, but, I will honestly say that this outfit will have less poke thrus than V3 ultra catsuit. I find there is one problem that I can not fix, it happens when either leg is moved forward into the exteme range(when thigh is adusted upward toward the chest). It causes a poke thru in front to the thigh and a little in the buttocks. One can always character inside invisable or if that does not apply with transparent MATs, one may have to avoid that pose. I have found with all clothing that sometimes you should transfer movement to the buttock or to the leg or vise versa. When you are covering this much of the body with one peice of material, its impossible to get absolutely perfect, but if you are familiar with my products, I will tell that this outfit fits better than anything I ever made before. For those of you who bought my MiniDress, I have found that if you transfer most of your thigh movement to the buttock, the bottom of the skirt will flow much better. thank you marty
The thigh in the picture is adusted at -84 forward. The poke thru is just beginning where I have the arrrow pointed. If you keeping moving the thigh more forward, the pokethrue continues to expand until its a big hole. This is cause not by a defect in my modeling, but its just the way that AnimeDoll/MayaDoll's thigh distorts when posing beyond -80 foreward on the thigh. Just look at her thigh when she is naked, you will see what I mean. thank you marty
That's pretty much what I meant by the buttock thing. Thanks. ^^ I know as a general rule of thumb, poses released by people don't put in buttock movements anymore because of the way they totally distort lots of clothing items. I guess that's pretty much a problem with Poser/the model instead of the clothing, since it's yet to be actually "fixed". I don't think I'd need to really bend her legs anywhere near that extreme on both counts (buttocks/thighs), but it's always good to know where the limits pretty much are as well as the numerous benefits. Thanks. ^^ I'll definitely be looking for this in the marketplace, let me know when you got it up so I can play too. Have many ideas for this thing...
And I did it!
I made a texture for the cat suit. I dunno if it works, so i'm hoping someone will try it out. A special Valentines treat. The texture is only for the base:
Just load the texture to the base.
Turn the seams ON.
And colour the seams red inside Poser.
It took a long time to do.
Here it is: (copy and paste link)
http://homepage.ntlworld.com/christopher.jarvis2/valentine suit.jpg
Happy valentines everyone! Tonight is indeed a night for celebration! The CatSuit has just been submitted to the MP! That means it will be in the Market Place by this day next week! The package is indeed, and I can say this because I am my own biggest critic by far,...this is the finest package I have ever produced. This is not the end of the package either, expect many MP addons and freestuff related to this package in the very very near future! I am impressed if I can say so my self how little explanation of use this package takes. Its as smooth as silk to load, conform and pose. It needs no tweeking for those annoying poke thrus either, it has JCMs like promised placed in verious trouble spots to correct fit with out the user even knowing! I have also inserted into the package 6 colors for fabrics, 6 colors for trims, 13 different ensembles (has it occured to anyone that there are a lot of bad numbers related to this product 6 6 13 friday 13th). And there is that one secret surprise that 3dZone and I have been holding out on you. I am leaving it up to her to make the official anouncement since worked hardest particular surprise bonus. Thank you everyone for supporting my effort. It woudn't have been the same product with out your influences. Special thanks to ynsaen, shadownet, and The3dZone for contributions to this project. Those of you who have been told of a mysterious Final Beta with a dead link, please contact me. marty
Funny YouTube video of the week - Bu De Bu Ai
SnowSultan is the one that makes "Seam Guides", and will do so usually on request if he has the figure.
