Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 22 6:50 am)
What you need is the CR2 editor by John Stallings which is in free stuff. (Just do a search for him). Open a file (CR2 or PP2) in the editor and go into the channels section. There you will see a label "hidden" - this is probably set to "0". If you change it to "1", the dial will not appear when you open the figure/prop. (You can do this in a word editor as well). This is how there are only dials for opening doors and nothing for scale/rotate in the Pickup Truck prop I did. Paul
There is a tool in CR2Edit for precisely this purpose, it will automatically hide or unhide dials without your needing to open the file in any kind of an editor, which can be very dangerous. One bracket deleted and the CR2 locks up. There is also a Bracket Checker in CR2Edit... Dan http://www.neca.com/~dwilmes/cr2edit.html
Attached Link: Is it possible to remove some of the dials ??
If you open a door it only rotates on one axis. And NEVER on one of the others. Is it possible to remove the dails for this for a new object ? I know it's possible to set the movement to 0 but as you seen, I don't need this dials at all. I don't even need scale and some of the other dials.
