Mon, Jan 20, 1:32 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 20 11:41 am)
Subject: Problem with eyebrows after converting texture and problem with eyes
Aeneas ( ) posted Tue, 10 February 2004 at 7:18 AM · edited Fri, 03 January 2025 at 1:04 PM
Rhis will most probably be obvious to most experienced users amongst you, but I can't find the answers. I've been using Uliversal Texture Converter to convert Blackhearted's Elowen so I can use it with V3. Before doing the body conversion, I did this trial render, with BlackEyes (I did chose V3 for left and for right eye, and the grey texture for both), and used his soft light. The result is a bit of a problem: V3's eyebrows shine through (I guess this has something to do with a transmap, or so?) and what's happened to the eyes I don't know. I use Poser5. Thanks.
I have tried prudent planning long enough. From now I'll be mad. (Rumi)
Mec4D ( ) posted Tue, 10 February 2004 at 10:07 AM
for the eyebrows set the TRansparency to 1,000000 and the Transpareny Edge to 1,000000 too. Daz set the V3 eyebrows wrong because when I load the model I get always the same.. I don't have BlackEyes so can't help you, I have only Dark Green/Hasel LOL j/K
_________________________________________________________
"Surrender to what it is - Let go of what was - Have faith in what will be "
