Wed, Nov 13, 7:53 AM CST
Vue F.A.Q (Last Updated: 2024 Oct 26 8:50 am)
Subject: setting to use for stucco texture
nick1 ( ) posted Tue, 10 February 2004 at 9:58 PM ยท edited Mon, 11 November 2024 at 6:51 AM
I am trying to use a stucco texture on this exterior low wall as displayed. How can I make it look more real? I played around with the scale a bit and it was better, but not quite convincing. Is there a layer/function under the BUMP tab tha can make this look more punched out? I have attached the pic and I will attach the texture if I can. Thanks in advance. Nick
nick1 ( ) posted Tue, 10 February 2004 at 10:01 PM
Here is the texture I used.
timefighter ( ) posted Tue, 10 February 2004 at 10:46 PM
This should do the trick for you.
James
timefighter ( ) posted Tue, 10 February 2004 at 10:47 PM
Here it is with the default settings
timefighter ( ) posted Tue, 10 February 2004 at 10:48 PM
Thanks to Alain Gracia for the awesome model James
sittingblue ( ) posted Tue, 10 February 2004 at 11:33 PM
Don't forget you can match the color map with the same map in the bump production. Also, you may want to try moving the key light source to an oblique angle in order to accentuate the bump of any material close to the camera. - Charles
Charles
nick1 ( ) posted Wed, 11 February 2004 at 12:51 AM
James and Charles- Thank you both for your immidiate response. I will try it again and shall I get into some other problems, I will trouble you guys again. Thanks, Nick
lingrif ( ) posted Wed, 11 February 2004 at 7:06 AM
I also appreciate the help here. I've been struggling with the same type of texturing problem - I always seem to forget the Object-Standard setting. Many thanks to you both and to Nick1 for bringing up the topic. - Lin
www.lingriffin.com
