Go here for V6 and V5 import tutorials......to do animation you need to export all your OBJ's from poser (with patch) and only select the weld box.......then import the first OBJ into cinema and copy and paste it, name the copy master and texture it then rename the original 1........then import all the others naming them 1, 2, 3 ect. and making them invisible as you go (make the traffic light red) then in the time line right click on master and go newtrack/special effects/morph ......then at frame0 rightclick and create new key and at that key double click and type in 1 (your first figure) then repeat for all your figures ans they will be animated :o).........Steve PS the animation bit is for V6
any tutorials out there ore anyone can tell me how i get my poser char to work properly in c4d ? thanks -Ede
