Thu, Jan 9, 8:15 AM CST
Subject: deleteing created fbm parameter dial
Aeneas ( ) posted Sat, 14 February 2004 at 8:19 AM ยท edited Thu, 09 January 2025 at 4:50 AM
Whilst experimenting in Poser5? I created a Full Body Morph which was added as a parameter dial. As this was only an experiment, I was looking for a way to delete it, but couldn't find one. The manual is not agreat help here (at least: I didn't find any answers there). Can I somehow delete this dial without having to change the text in the obj file itself? Thanks. About this obj file: I used the rdna free nostrils noglow prop, and instead of filling the nostrils, it was placed on the cheek. I did delete this one in the obj file...so it can be done, but I prefer other ways...
I have tried prudent planning long enough. From now I'll be mad. (Rumi)
PhilC ( ) posted Sat, 14 February 2004 at 9:05 AM
Open the hierarchy window and select to view all parameters. Your dial will be there listed. Click on it to select, then hit the delete key. Note that if you try to do this with a fully loaded V3 you may run into trouble since there are so many dials.
Aeneas ( ) posted Sat, 14 February 2004 at 11:08 AM
Thanks. It is V3 with all morphs loaded...think I'll save a copy first...
