Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 26 6:57 am)
I had a similar problem when I first used the Behemoth model, but what I discovered was that the geometries files were corrupt. So I deleted the geometries and then reinstalled them, after that everything worked fine. The textures for the model should be in your textures folder and can be found in the Pose directory, either under Sixus1 or Behemoth. If they are not applying automatically you could go into the materials room and apply them manually or get correct reference from freestuff and run that to fix the problem. HTH 8) Catlin
First, thanks to everyone who cares about it ! "Angered", "P4 Default", "PP default" are in Behemoth folder. I show you the way : Program files->Curious labs->Poser 5->Downloads->Runtime->Libraries->Pose->Behemoth and then angered... I hope I understood your question...I'm french. An answer to Catlin too : I tried not to apply P4 default or PP Default and put the textures "manually" in the material room, but my PC froze after fifteen minutes. I tried today to export Behemoth to Vue4 (as a Wavefront OBJ), RightPinky3 is OK in Vue. But Genitals were flying 5 inches behind him !
