Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 02 7:25 pm)
Are they showing up while you are working in Poser? I just wonder if they are like MS Word's temp file, which opens when you are using a file in Word. But, like I said, the only time I've noticed these pzSav_blah.pz3's is when, for some reason or another, Poser didn't finish doing something. Sometimes it opens and is a perfect copy of whatever I was working on and sometimes it is a single light, black and off, with nothing in the pic. If you don't need it (ie, it's not the instance when it just crashed and actually saved your work), delete it.
When Poser saves a file, it sometimes renames the original to the pzSav_originalfilename form. When it's finished saving, this backup is deleted; if it crashes while saving, you can rename the backup to get your work back. It would be a wonderful feature, except most of the time the pzSav version isn't made, and I haven't been able to find out why. If you have Windows Explorer (or equivalent) looking at the appropriate folder while saving, you'll see these pop up from time to time.
Nance: that's right, Poser 4.03, under Windows 2000. Jerr3D: I think Triarius used the ##### as a placeholder for the rest of the filename - I certainly haven't seen any hashes. Say if I'm saving a file named 'fred.pz3', then the temporary file (if it exists) will be named pzSav_fred.pz3. Triarius: Don't I know you from somewhere? :) I admit I have never tried using one of these pzSav_ files for real, that was just an assumption I made. A poor one by the look of it. My bad. :)
What is it, why is it here, what is it for? Files named like this, starting with "pzSav" and with a random string of characters just in front of the pz3 extension keep showing up along side my bona fide files. This is on a Mac running OS 10.3.2.
