Wed, Feb 5, 2:35 PM CST
Subject: HELP! Missing Poser files
silverwolf8895 ( ) posted Tue, 24 February 2004 at 1:25 PM ยท edited Wed, 05 February 2025 at 2:31 PM
I recently installed Poser 5 but I cant seem to install it correctly or something, I dont know exactly what the problem is except for the fact that during the setup process it tells me that there are CRC checking errors. There are supposedly 3 files missing..i located 1 of them but maybe there are mulitple files by the same name? the files im missing are as follows:
morphs.ph5
Judy Nude HiRes.crz
Is there any way I can get those files? if so PLEASE contact me as soon as possible.
Thanks
mateo_sancarlos ( ) posted Tue, 24 February 2004 at 1:49 PM
Where did you download it? Maybe they can send you the files, or set up a new download that has all the files. Did you use the par2 files to fix any errors?
silverwolf8895 ( ) posted Tue, 24 February 2004 at 1:55 PM
I installed it from the Poser disk. During the running of Setup.exe those errors popped up, heres the exact message: CRC checking failed. 'morphs.ph5' was not copied correctly CRC checking failed. 'Judy Nude HiRes.crz' was not copied correctly CRC checking failed. 'Grab.png' was not copied correctly. I have no idea where I am supposed to get these files. any help would be great. I am assuming that anyone with just Poser 5 would have these files since that is all I have. I havent gotten any extra stuff like extra clothes or models for P5. But those are the only files that seem to be missing. Any help would be great.
SamTherapy ( ) posted Tue, 24 February 2004 at 2:01 PM
Contact CL with your serial number. They may give you a downloadable link or supply you with a replacement CD. Nobody other than CL can legally supply the missing files.
silverwolf8895 ( ) posted Tue, 24 February 2004 at 2:13 PM
ok thnx
Bobbie_Boucher ( ) posted Tue, 24 February 2004 at 3:52 PM
It's possible your CD is dirty. Just get a good CD cleaner and clean it. You can probably get them in any department store for $10 or less. You can use the same cleaners that work on music cd's. You can also get a good cleaner for your CD ROM drive. (If you have a CD burner, read your manual before attempting to clean it.)
biggert ( ) posted Tue, 24 February 2004 at 6:00 PM
you can also return the software to the store you bought it from and exchange it for an identical copy
silverwolf8895 ( ) posted Tue, 24 February 2004 at 7:37 PM
Thanks guys. Much Appreciated.
