Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 05 8:40 pm)
What's it worth to you? You could pay $15,000 for a face scanner, wait for me to get back here with some nation wide Scanner Studio Links, pay $500 and then $20 a pop for the Facegen techies to make them for you from photos you mail to them, else you must request of someone, like myself, whom has this application, and can thus do more legwork for you!
If you have a digital camera and a tripod, the best thing to do is take a couple of head shots. Do one profile, then one straight on, and use those as reference. To keep the profile and front shot consistent, use a line on the wall behind your head and have another person (using the camera) tell you how to tilt your head so the tip of your nose and the corner of your mouth line up the same for both shots. good luck.
Also be aware that none of the Michaels are Face Room compatible. Only the stock P5 characters are. On the other hand Michael has more morphs, so depending on how close you are from the start you should be able to get pretty close. A good idea is to load the picture of yourself (the profile) as a background picture, then line up Mike and start pulling. Use the Left (or Right) cameras, not the Main Cam or Face while aligning to the profile pic. Then do the same with the front pic but move Mike so that you can see both the pic and him and pull more. The Morph putty is said to be better in SR4, so that it should work better with non-stock characters such as Mike, so it's woth a try.
Hi, could someone tell me the best way I can morph my face using the michael models in Poser, or direct me to a tutorial? ie..Photo line up Face room Many thanks
