Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 12 11:30 pm)
_________________________________________________________
"Surrender to what it is - Let go of what was - Have faith in what will be "
this show only one example of what you can do and is really simple... more as this looks like.. will preapre everything and upload to my server as well..give me a five moments
to get the reflection of the object right you need to add volume but this will well slow down your rendering and with to much value your computer can crash or stop with rendering.. as this happend to me right now.. lol to much is not always good.. working on the new sky textures..
Thanks :)) I am working now on advanced UV's mapping for the universe( sky so you can move the camera on top on the sky as it will looks like in reality without any deform and distorts.. will upload as I am finish + other scenes as bad weather day, night, sunset etc.. + ground and one surprise.. I think the new terain tools for Poser that are right now in production by one of our member will open a new Poser world in excellent way.. together with this universe
Wow, this looks really great. I've been modeling some plants, and have decided that I like PP renders better than Vue 4, if I'm careful enough with lighting.... The best part of poser is that you take a plant that is fairly small, load up a bunch and pose them by bending stems and moving leafs around, and you have carefully articulated plants well beyond anything that Bryce or Vue can do....and they can look nice rendered as well. If they would just come out with point lighting so we can do indoor renders, everything would be great:) eric
yes Eric.. I create now also some simple ground for the panorama.. I have Vue too but is slow when rendering small animation so I got on this idea for poser to get the nice reflection and movements of the camera without to worry about that the square is to small.. now it will a real world for sure.. and open new ideas.. the light I used above is simple 5 lights.. very quick rendering and great effect.
This looks fabulous, Cath!
View Ajax's Gallery - View
Ajax's Freestuff - View
Ajax's Store -
Send Ajax a message
the ball unverse is new prop with relaxed UV's so your textures will looks perfect but not simple to do... but you can use also very low textures minimum 1000x1000 and scale it down too to get perfect effect with low textures, you need to create tiled textures for the ground and the sky ball.. the ground textures you see here will included too so you can see how to scale your own down to get the best effect..
Attached Link: Download Universe for Poser5
Ok here is the zip file with the first scene but that is not everything.. more nice skies textures coming tomorrow.. + some ground props..here is also template inside the zip in bigger format..
maximum textures for the skyline is 4000x2000
the first pz3 include the scene with shader clouds node and the second one the template.. is more exact..
if you have any question please let me know
Note: if you render close up please use the Focal of main camera to max 250.. and if you render distance don't get minder that 16 mm, don't change the position of the TOP SUN spot light.. you can change any other , the front light include shadows, plug all your new tiled ground textures under the node you find in the scene.. plug in the sky textures only under Alternate Diffuse other will not working the right way and you get studio in place of outdoor effect.
Thanks Literata! just open scene and render first to see the speed.. in some scenes you just can't without that why I did this and I hope my 9 hours of non stop work was not for nothing.. and you can use it in your work. Now when the base is done I can create the final figure of the Universe without the background etc.. this will much better.. Cath
Cath, this looks so cool! So how do I change the texture on the ball? With the template you provided? And what about the ground texture? Can that be changed? If so how? Thanks for sharing this :) I have it opened right now in poser!
Poser 9 SR3 and 8 sr3
Processor Type: AMD Phenom II 830 Quad-Core
Hard Drive Size: 1TB
Processor - Clock Speed: 2.8 GHz
Operating System: Windows 7 Home Premium 64-bit
Graphics Type: ATI Radeon HD 4200
System Ram: 8GB
Sallie everything can changed just open with Poser and in the material room there you can just change the textures but not remove the nodes just replace with other.. I will start new topic right now it is hard to read :))
ah when you mean the ball that reflect the universe then there are not maps.. just reflection node nothing more, change the sky-ball textures.. not the ball from the scene.
Thanks Cath :)
System Ram: 8GB
Attached Link: Part II check out
You are welcome :)) we switched to other topic where I uploaded right now first dynamic water test animation in the scene..looks cool check out.. Cath_________________________________________________________
