Mon, Feb 10, 3:08 AM CST
Subject: I could start to really hate windows......
Melansian_Mentat ( ) posted Wed, 03 March 2004 at 1:24 PM · edited Mon, 10 February 2025 at 2:57 AM
I am having tremendous difficulty with my latest image..... aside from not having much time to work on it, I'm also trying to create a basic triangular prism..... Hard to explain.... the piccy below puts things in perspective, but this should give you a general idea...
Melansian_Mentat ( ) posted Wed, 03 March 2004 at 1:26 PM
That line is where the window is meant to open, but I just can't think of a way to make that apparent. Any ways of making the actual glass look frosted would be really great, too!!!
draculaz ( ) posted Wed, 03 March 2004 at 1:30 PM
can't you make a negative boolean of a high cube so you can have that divinding line? as for frosting, just give the glass a default bump of some sort.
Melansian_Mentat ( ) posted Wed, 03 March 2004 at 1:37 PM
..... How can I put this..... my biggest problem isn't technical.... it's just that I don't recall ever seeing the kind of window I'm trying to create. I really don't know how wooden windows are constructed, so I don't know whether to put something between the two sides, or what? All the windows here are..... welll, odd. Like all the rest of the architecture... And I really don't know what kind of bump to use!
sdnoble ( ) posted Wed, 03 March 2004 at 4:03 PM
If you construct one side of the window frame and cut a 45 degree bevel using booleans, then duplicate it and position it by hand against the other side, you are sure to have a small gap. If I am envisaging the kind of window you are making right, the frames should just butt against eachother with no divider. Giving a standard glass a bump, white diffuse value and a touch of white ambience can make an OK frosted glass look.
Erlik ( ) posted Wed, 03 March 2004 at 5:21 PM
This functions quite well.
-- erlik
Ancience ( ) posted Wed, 03 March 2004 at 10:09 PM
i hate windows too...but i can't anything that might help, im new to bryce
ysvry ( ) posted Wed, 03 March 2004 at 10:33 PM
i hate macs as they atract snobs :P
for some free stuff i made
and for almost daily fotos
shadowdragonlord ( ) posted Thu, 04 March 2004 at 4:21 AM
I make, design, and sell windows. For NW Exteriors. And I hate them with a deep, intense passion! But honestly, I'm not sure I follow what the problem is here? Is it material based?
violet ( ) posted Thu, 04 March 2004 at 5:53 AM
There has to be something in the middle so you can lock the window....you've got quite a challenge here ;-)
FWTempest ( ) posted Thu, 04 March 2004 at 11:09 AM
I own a wholesale window and door distributorship which I inherited from my grandparents last summer.... which is why I haven't been around much since then... and I must admit that I'm having trouble following what you're trying to do, too. Actually, what it looks like you've got going is what we call a French door, two doors hinged at the jambs (sides) and locking together in the center. If this is the case, then in your image the corners of these doors (or window sashes) are touching while the doors themselves are at a right angle to each other (judging by the position of the knobs). I'd have to say, based on what I can see in your image, is simply to make each "side" of your window separately. Place the two sides together as if the window were closed. Then rotate eace "side" at the point where the hinges would be (can you move an objects "hot point" in Bryce?) to open them. Also, there would be some sort of projection on one of the "sides" which would overlap the outside of the opposite "side" when closed to prevent weather from getting in. Hope this helped some.
FWTempest ( ) posted Thu, 04 March 2004 at 11:10 AM
BTW... very nice plates you've got around the knobs
shadowdragonlord ( ) posted Fri, 05 March 2004 at 4:23 AM
Aye, I agree with everything FWTempest said. Windows can be obnoxious, but can be made to be fully functional for animation... Here's my most postworked attempt at a window setup, although totally unrelated to yours...
Melansian_Mentat ( ) posted Fri, 05 March 2004 at 7:48 AM
This has been some really great info, guys! Sorry to be so vague, but I really don't know what I'm aiming for at all. This is just an attempt to recreate the view from the window in Harfang in the Silver Chair by C.S. Lewis. The bump idea is cool, but would that make the frost patterns too? Hehe, just realized I don't exactly live in a place where you would see that, either.
