Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 26 6:57 am)
As a software engineer at a fairly large printing house, I'd have to say that QUALITY prints will need a better dpi than 72. 300 being about the minimum. Most digital printers (I assume your not making 10000 copies of your calendar) eat wasily 1200 dpi images - the quality is directly influenced by your choices in making the rendering. Most home-users will have limited amount of memory though, so maybe the suggested 300 dpi is enough, but in that case you should run a production-quality test -run before you submit your work to a printer - in case you are using a commercial printer.
Normally, offset-printing is done either at 60 lpi (lines per inch) or 70 lpi. For 60 lpi you need 305 dpi (dots per inch) resolution, for 70 lpi you will need a resolution of 350 dpi. Do not hit to high on the dpis, or you may risc getting a moire-pattern in your prints. If you are aiming at a mathematical-raster-print, you'll need your pictures at about 400 dpi - the rest will be done by the RIP-software. You should render the image at maximum resolution possible in Poser (4096 x 4096 pixels) and cut and resize it to fit your printing-size + 3 mm on all sides (bleed) When converting from RGB-colours to CMYK, make sure to use a solution for art-prints or else your pictures will look flat and greyish in print. If you need any help in converting the pictures for print, I can help you. I am doing this kind of thing quite a lot.
Hello folks :) I'm creating a calander of saucy women for a disabled bikers charity and was wondering what defintion people use when rendering to produce nice sharp prints. As I recall the default for Poser is 72.00 pixels/" but how high can the settings be? Thanks for the time Mon
