Sat, Jan 25, 1:28 PM CST
Subject: Where can I find a tutorial on readscript ?
compiler ( ) posted Sun, 07 March 2004 at 3:01 PM ยท edited Fri, 10 January 2025 at 6:48 PM
I have read many interesting threads that deal with readscript, but I have no idea how this worms. I have seen it used in a cr2 to call other cr2s, but more than that I cannot tell. Do you know where I can find a tutorial that would explain the basics of this ? Thanks in advance.
lesbentley ( ) posted Sun, 07 March 2004 at 3:16 PM
Attached Link: http://www.rbtwhiz.com/rbtwhiz_rScript.html
There is a tutorial by Rob the Whiz (perhaps not the clearest thing I ever read).
compiler ( ) posted Mon, 08 March 2004 at 2:30 AM
Thanks a lot. Readscript does make more sense to me now. Since I use Poser5 and I don't have Vicky3, it may seem to be less important for me, but the copyright protection and the memory reducing uses still are very interesting.
maclean ( ) posted Mon, 08 March 2004 at 2:38 PM
Here's a little thing I discovered about readscript. You can also include readscripts in a .pz3 file and they work. What you have to do is replace all geometry references, actors and figure blocks with the appropriate readscript pointing to a cr2, (and leave all the other pz3 information, like lights and cams, intact). In other words, one line for each character instead of the entire obj/cr2 references. I thought that this method might solve the problem I was having with readscripts calling multiple cr2s (where the BODY numbers don't write properly), but unfortunately, the problem's still there. Still, it's an interesting way to cut down pz3 size considerably if you only have one character. mac
