Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 31 9:45 am)
I see you already have your answer...but I will add a bit of OT to this. It is a good idea to re-set your virtual memory every once in awhile just for safety sake. I make it a part of my routine disk maintenance at least every 2 weeks. VM can get corrupedt very easily if you are on the computer a lot, and it can cause operational problems.
And how about the settins? I'm sitting here with my new computer and feeling like a total blonde becourse I simply can't remember the best settings... Something like twice the physical RAM as far as I remember, but is that as max or min setting? I just ran out of memory during a session in VUE (most likely becourse I had Poser 5 running too) so I wanted to optimize it.. And found out I forgot the settings. HELP?
I am a total twit and can not remember how to change my virtual memory paging size thinggy. I did it once when poser was telling not enough memory dialog when rendering but can not for the life of me remember how to do it again.
https://www.darkelegance.co.uk/
Commission Closed till 2025
