Tue, Nov 19, 7:36 AM CST
Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2024 Sep 18 2:50 am)
Subject: Can't use the pose functions before closing GUI scripts
mbk ( ) posted Thu, 11 March 2004 at 7:23 PM · edited Thu, 14 November 2024 at 11:40 PM
file_102029.txt
I'm new to Poser python scripting so forgive me if this is obvious. I was trying to build a form with a button to insert a figure in the scene. The script worked, but it appears that you cannot start posing the figure (or use several parts of the main Poser interface) until you close the form. Is this true or have I just done something wrong? I've included the code I used and I'm running Poser 5 SR 4 on a PC if that makes a difference - thanks for any hep you can give
mbk ( ) posted Fri, 12 March 2004 at 11:34 AM
file_102030.txt
OK - figured this out. You have to cede control from the script back to Poser by calling scene.ProcessSomeEvents() every now and then from the GUI. This is best done using a timer (the after() method) as shown in the code sample attached. Hope this helps other folks out too, which is why I'm posting a reply instead of just deleting the post
nruddock ( ) posted Fri, 12 March 2004 at 1:56 PM
See this thread for links to others that deal with this aspect of GUIs.
The scripts available in the "Free Stuff" are the best reference on how to do it.
