Sat, Jan 25, 7:22 PM CST
Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2024 Dec 02 3:16 pm)
Subject: Problems with Daz's Mat Manager Python Script
dvitola ( ) posted Sun, 14 March 2004 at 9:43 AM · edited Sun, 19 January 2025 at 12:53 AM
I sure hope you can help me since I've written to everyone else in the world and no one knows the answer. I just bought the Mat Manager at DAZ and have loaded up the script according to instructions, reinitialized it, etc. I've loaded a Mil figure into the window and selected it. When I try to run the script, I get the following window. Traceback (most recent call last): File "", line 10, in ? ImportError: No module named dz_mm I'm not quite sure what to do to use this software. The Help instructions aren't very helpful. I'm using Poser 5 on a Macintosh G4, OSX 10.2.8. Can someone help? Thanks in advance, Denny
nruddock ( ) posted Sun, 14 March 2004 at 11:44 AM
I don't have a Mac, but I gather OSX 10 is sufficiently Unix like that I can probably help.
First step.
Is there a file or files whose name(s) begins with dz_mm under the directory tree where you installed it or under Runtime/Python ?
If yes, then please list them and their locations.
If not, then only DAZ is going to be able to help.
dvitola ( ) posted Sun, 14 March 2004 at 6:46 PM
Hi nruddock--I found a dz_mm.pyc under the rsc directory for Poser 5 (Runtime/Python/DAZ/MATManager/rsc/p5) Hope this provides some clues. Thanks! Denny
nruddock ( ) posted Sun, 14 March 2004 at 7:20 PM
Good start.
It seems that the problem is related to the Tkinter module that Python uses (see the DAZ forums).
This link may help How do I install Tkinter? How do I get IDLE to work?"
An additional complication is that you almost certainly need to get versions of the necessary things that match the Python that Poser was compiled against (which was 2.2.x, x >= 1 for P5 on Windows).
This is definitely geeting into territory where I don't have enough specific knowledge to really help, so you'll need to use the MacPython resources for detailed stuff.
This thread Python on OSX has some ifio that may be useful when asking questions.
nruddock ( ) posted Sun, 14 March 2004 at 7:32 PM
That should have been "getting" not "geeting".
I won't get to check for messages again before DAZ opens today (seems like they'll have a few similar questions to deal with), so you may get an answer from their tech support before I see any reply.
dvitola ( ) posted Sun, 14 March 2004 at 8:27 PM
Thanks, nruddock. I have to admit, all this is way beyond me. I hope DAZ can get me an easy fix. This is the first time I've tried a Python script, so I know zero about the process. Denny
