I agree with whats said above, I got P5 last nigth and IM runnign the tutorials here as well as various other sites and Im already beginning to learn to walk (so to speak) if you want to get into 3d there is no better way that using poser in my opinion. hey are having a sale @ curious labs so that would also make it attractive.
I've found that P5 is a little harder to learn, only because it has a lot more options. I admit I've had P5 for a year, but I still pose and compose scenes with P4, get everything set the way I want, then save it and open it in 5 for the final render. If I had to mention my personal favorite difference, it's the focal distance in the render, so you can have the main model be in focus, but the background is slightly blurry, just like a real photo would look. The materials setting are the next best thing just because of, again, the vast amount of options you have. There's my two bits. :) ~ Rich Oh, and speed? The more detailed you want your image the slower it's going to be. Simple render, just a few minutes. Focal point, lighting, AA, etc, mine usually take an hour or two to render. (Compare that with Bryce! Longest render time THERE was 72 hours!)
If one were to use basically the same settings (AA, lighting, etc.) and scene for Poser4 and Poser5, which one would be faster and to what extent? I hoping to do some animations and anything over 3 or 4 minutes with AA, simple lighting, one figure and 640 x 480 NTSC product is going to be really painful. (It already is in PoserPro;) Thanks again. manowar
The main concern is, speed is decided by your system, how much ram and what OS. in my opinion, if you dont have XP with at least 512 in RAM, do P4. Its hard to judge speed due to the apples and oranges nature of the two, For example I find the material assignment to be more intuitive in P5 than the tedious dropdown in P4, so I save time there. render methods, P5 has the firefly render and for low end renders the p4 engine. Agasin, Im sure more versed people could offer a better review than I, but I was where you were a bit ago with trying to decide to get it. For me the library function practically puleld me over as p4 libraries just plain get to cumbersome with V3, M3, freak and whatnot.
You might want to try Poser Artist for a $99.00 you can create great looking scenes with less of a learning curve. It depends too, on how much you want the options that only P5 has. Dynamic cloth, hair, are mostly things you'd use for annimation, if you are mostly going to do still renders then they wouldn't effect you much. The Face room in P5 would mostly be useful if you want to do your own texturing. The P5 material room is overly complex and I don't see much of an advantage to having it. Poser 5 has been plagued by many bugs and already is into the 4th service release patch to correct them after a year and a half on the market. I started with Poser 4 (now called Poser Artist) and added Pro Pack, I purchased P5 as soon as it was released and have hardly used it. I found the documentation poor and difficult. The biggest innovation in P5 is the Firefly rendering engine, as far as I'm concerned and I've mostly built my scenes in P4 and opened them in P5 for rendering.
Right now I'm using PoserPro on a Mac. The biggest problems are its rendering speed versus other programs like C4d, a horrible bug that it has with a higher version of Quicktime (scene freezes after generating a movie), and its reliance on the old Mac System 9.x. The only good thing about it is the availability of a C4d plugin by CL that allows much quicker animation rendering in that program. Going to Poser5 gives me the option of staying on one operating system, MacOS X, and possibly, a better, faster renderer. I understand from the above that the firefly renderer is better as to quality and additional options, however, no one above has stated it is faster with equal scene, identical settings, and identical hardware. I'm trying to determine if a hundred dollars is worth the attempt to find out. What a mess to be caught between two operating systems, two Poser Programs, and with an update, now being unable to go to a third program for animation rendering speed. manowar
I'd say it is more difficult to learn than Bryce or Vue. I still don't use it at its fullest and I've owned it for over a year. Never owned P4. I wanted it mainly for the character posing ability. Vue and Bryce are way better for landscapes (although RDNA has done a terrific job of helping in this area with their Microcosm's). I really think the material room is one of P5's best features. Once you read through the tips and tutorials that are available at RDNA, Poser Pros and here, you can get some really amazing results with it. Check out RDNA, Sixus and Cubed products for examples of good use of the material room. The face room only works with the native P5 characters and involves more putzing around than I want to do :) I've never used the cloth room, but a lot of people do and really like it. The hair room is not for the faint of heart (or for anyone with less than 1 gig of ram!). The more ram you can afford.....the better. 1.5-2 ghz PIV or equivalent processor (or better). Windows XP or Windows 2000. I don't know if it supports swf files, since I don't do any animation or movies with it. If you get it and run into problems, search out posts by Ynsaen.....the local "P5 guru" :) Layingback (I think that's right) also has some good tips on getting rid of "Content Parasite" and other neat stuff. If you get it, update immediately to SR3 (there is a newer patch, but it seems to still have some "issues")
Thanks for your info. It appears that P5 is more complex but in those areas particular to my work, animation and rendering speed, may be very similar to P4. Were Curious Labs to update their plugin for C4d with P5, I would jump at purchasing both, but I believe this is not going to happen anytime soon:) manowar
Just read thru some of your posts Man O' War. I don't own P4, but I don't think I've ever read that the firefly renderer is faster. I have read that it is better. I have also read that some people find P5 way slower on the same machine they run P4 on. If you're only looking to speed up renders on an existing machine, a move to P5 may be a disappointment.
Hi! I've no experience whatsoever in using 3D software, with the exception of Bryce 4 and Adobe PhotoShop. I'm thinking of getting Poser 5 to try out new things, and my question is : 1) With a user my level, will Poser require a steep learning curve?(like 3D Studio Max, for example) Bryce is pretty easy to learn, so I wonder if Poser is as easy to learn as Bryce?(by learning, I mean getting comfortable with the software and can make at least some cool basic faces) 2) In Poser, is it possible just to create the heads with dimension size of up to 2400 * 3000 pixels?(just the heads) 3) Is it easy to create a basic face that looks like a human FROM SCRATCH?(don't have to be so extremely realistic or detailed.....just recognizable will do) Thanks! Xeon.
