Fri, Nov 22, 1:34 PM CST
Subject: More about Poser 5 hair collision
kirwyn ( ) posted Fri, 19 March 2004 at 6:44 AM · edited Wed, 20 November 2024 at 3:32 AM
Thanks to the helpful members that responded to my last thread about hair collision. I started playing around some more and found something that may interest you. I checked the collision detection in the parameters's properties of the body parts, such as the head, neck, etc.(parts that will collide with the hair), then ran the simulation with the "do collisions" box enabled in the hair room. It actually worked pretty well for the most part. If you use the stock dynamic hair supplied with Poser, the simulation will run a lot quicker using Judy. But for some crazy reason, I usually have to run the simulation twice before it takes effect. And if you have Vue 4 with the latest update, it doesn't take long to run a preview animation with shadows....half the time Poser takes to run a preview without shadows. Anyway, I hope this is helpful.
maxxxmodelz ( ) posted Fri, 19 March 2004 at 9:44 AM
Yeah, I've done this and it's fine for a single pose, but for animation there are still some collision problems, even with all the collision detection options selected. But thanks for the info!
Marque ( ) posted Fri, 19 March 2004 at 12:43 PM
Well I've tried the collision on and it still goes through the face. What am I missing here? Isn't it odd that CL has never addressed this? It's like if they ignore the problem we will give up and go away. Marque
nerd ( ) posted Sat, 20 March 2004 at 5:57 PM
Forum Moderator
I've done a LOT of fiddling around in the Hair room and I recently made some interesting discoveries, the most important is the strange behavior of the "Bend Resistance" dial. I believe the default value of this dial is something like .8 which is WAAAAY wrong. .01 is more like it. Simply setting this dial to a very low number will make hair simulations go much better. P.S. Get SR4 there are lots of improvements. Nerd
Marque ( ) posted Sat, 20 March 2004 at 8:04 PM
I have SR4. I will turn that Bend Resistance down, and any other tips you have are appreciated as much as that one! Thanks, Marque
