You can make an icon easily: just prepare a PNG, 91 x 91 pixels. On Poser 4, you need to convert it to RSR format with P3dO Explorer. You'll also need a blank PZ2 file for the icon to attach to. Copy the text between the --- lines: --- Start --- { version { number 4.01 } thighLength 0.17748 figure { } } { version { number 4.01 } thighLength 0.17748 figure { } } --- End --- - paste into a text editor, and save it with a .PZ2 extension. If you give your PZ2 and icon files a name starting with ! it will make them appear at the start of the list. If you already have poses starting with !, then use !! or !!! until you win the exclamation mark battle. :)
Alpha channels, png to rsr, 91 pixels... huh?? Just do it the easy way: 1) Make a square image in your favorite image editor (Photoshop, Paint Shop Pro, whatever.) 2) Decorate it however you want: requirement text, your face, whatever. 3) Save as jpg. 4) Open Poser (4, Pro Pack, heck, even 3). 5) Add a small object to scene (a figure if you are in the figure or pose library, a prop if you are in the prop library) 6) Set the background image to the image you just made. 7) Make the figure or prop invisible. 8) If the quality is good enough, hit the + to add it to your library: there, a nice thumbnial. 8a) Or, render the scene, paste onto background, then add to your library. Then, edit the figure (or pose or prop) file so it's blank, so people don't click on it later.
Or just use P3dOExplorer. It does a nice job of converting .png without alpha channels to those with! :) Kuroyume
C makes it easy to shoot yourself in the
foot. C++ makes it harder, but when you do, you blow your whole leg
off.
-- Bjarne
Stroustrup
I see you have got some answers, I havent read them all but I can see i am largly repeating what has been said already. Never the less, here is my take on it. About the best you can do is to create a minimal library file file, one that is almost empty. Poser needs an associated library file other wise it won't display the rsr or png for the thumbnail. The minimum file consists of an oprning brace, a carage return, and a closing brace. Poser will still try to load this minimal file but in most cases it won't do anything. There are two exceptions, if you use it from a light pallet it will turn all the lights off, and if you use it from a figures pallet with 'Change Figure' it will delete the figure from the document. Here is a procedure, I tested it in Poser 4, but I think it should also work in Pro Pack and Poser 5. 1. If the item is a prop go to step #3, If the item is a camera go to step #4, if the item is a figure or pose go to step #2a. I recomend you don't use this procedure for lights. 2a. Load any figure (one with a small file size is best). 2b. Select the 'BODY' actor. 2c. Hide the 'BODY' actor (select it, then from the menu bar; Object > Properties > Visible). Go to step #4. 3. Hide the prop (select it, then from the menu bar; Object > Properties > Visible). 4. Import the graphic you want to use for the icon as a 'Background Picture". 5. Save an item to the pallet. 6. Open the library file you just created in a text editor. Select the entire contents of the file and delete them. 7. Type an opening brace, a carage return, a closing brace, then resave the file. It shouild now look like this:
Thats it! As Twisted_Symmetry said using a "!" as the first character of of the name will bump it to the top of the list.
