Wed, Jan 22, 1:05 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 22 10:04 am)
Subject: Quandry: Highlights with transparancy in P4
Ghostofmacbeth ( ) posted Fri, 19 March 2004 at 7:38 PM ยท edited Wed, 22 January 2025 at 10:05 AM
I know it isn't suppossed to be possible but someone said it was but I am still not sure. I am trying to get a transparancy on an object with some gloss. Apply texture to highlight or not doesn't work. The only way I have found to make it possible is to have black in the texture or to use the transparancy as the texture map and color it using the material colors. Is there something that can be done? Thanks
geep ( ) posted Fri, 19 March 2004 at 9:46 PM
Hi Ghostofmacbeth, Try using just the Transparency parameters. The highlight will still show up. cheers, dr geep ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
Ghostofmacbeth ( ) posted Fri, 19 March 2004 at 10:50 PM
Thanks but I am trying to get rid of the gloss on the transparant part. I am messign with the M3 Cloak and I want to loose the hood part but I want the cloak to be slightly glossy but not the invisible hood..
Valandar ( ) posted Fri, 19 March 2004 at 11:28 PM
Then make the hood part of the texture 100% black.That's the only way.
Remember, kids! Napalm is Nature's Toothpaste!
geep ( ) posted Fri, 19 March 2004 at 11:49 PM
... or ... Use the "Grouping Tool" to make the hood a separate group. Then you can control the hood and the cloak separately, no? cheers, dr geep ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
Ghostofmacbeth ( ) posted Sat, 20 March 2004 at 12:09 PM
Yeah .. I was trying to have some versitility in the cloak but that might be the only way (texture) Can't really group it because you need to encode things or something or other .. Plus the grouping tool stinks ;)
geep ( ) posted Sat, 20 March 2004 at 1:55 PM
Re: "... Plus the grouping tool stinks ;)"
Hi Ghostofmacbeth,
If you really think the grouping tool stinks ...
You might want to look at THIS
  • or -
You might be interested in looking at THIS.
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
