Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 12 11:30 pm)
Ah ha! Good call I just re-installed everything after having to reformat because of WindowsMe. I must have hit depth-cueing when I was turning on full speed tracking. (I don't even know what it's for?) I rendered again and it's fine..except those lines are still appearing on the shorts? (shorts are free at zygote today for anyone who has Michael) Thanks for the help Jeff
I just re-loaded the shorts to try and figure out why those lines are appearing. They only appear when I add the texture. I tried using the texture as a bump map instead and I got this weird artifact that you see just above the shorts. When Michael is in the scene it appears as part of his skin and is aligned with the joint between his chest and stomach?? Weird
The garter thingie is named "chest" and is in the materials group "skin". The default settings for thransparency min and max for "skin" are 100% when installing the shorts. It renders invisible, and probably fits inside Michael anyway. You could also uncheck the "visible" box in the properties dialog for it, then re-save it to the library.
Yeah.. I see that 100% is the default setting under 'skin' (what's the diff between the 'skin' and 'shorts' settings?) I selected 'Body Parts/Chest' and found the area you mentioned under 'Object/Properties' and saved the shorts with an 'invisible' chest property. What is that thing anyway? Something that helps the shorts to stay aligned or move properly? Thanks for the tips wulf
Clever I've just switched to a texture by the amazing Catharina. I figured out problems I was having with lips and nipples. The body color was way too dark and I fixed that by changing the color to white. I'm still trying to figure out how to get rid of the black eyebrows though. I tried drawing on the texture.jpg but it's a photograph and it's kind of tough to keep it real. I'm going to buy her different hair color templates now... but I'd like to be able to change the color of those eyebrows... and the goatee on the 'alternate' head texture. (Using Michael's eyebrows over them didn't work too well. His eyebrows look best with a lot of transparency and the black ones showed through)
Yeah, Dillinger, usually the best thing to do with a figure is to set the object colors to white, and then save it to the library so you don't have to go through it all again, that way the texturemap shows better. I haven't purchased Catharina's maps yet, but I intend to. She is an amazing artist. Changing colors on a part of a texture map would be a tough job. If you can select the eyebrows by color, and get most of them selected, you might have an easier time. Try changing the color, tone, and hue properties. Maybe even brightness and contrast.
I've taken the face map into fireworks and tried selecting it with many different degrees of 'tolerance' .. but I'm not getting very good results no matter what effect I try and apply to it. I'm going to just try and draw over every hair using my graphics tablet and see how that looks. It's tricky because the lines you draw are pixellated when you're zoomed way in.
