Thu, Dec 26, 7:29 AM CST
Subject: Help...creating thumbs for mats
garrr ( ) posted Thu, 25 March 2004 at 3:16 AM ยท edited Thu, 26 December 2024 at 7:16 AM
I have created some rsr files and want to edit the 91x91 png images into them using the latest version of P3do explorer...but it is not working as it should be as i have done this before and now the way i used to do it is not working...All i used to in P3do was to open up an png file, click edit image, copy..close the file and go to the rsr file, click on edit image, paste and save or save as. Now all i get are blank rsr files when opened up in poser 4 or pro pak.
yarp ( ) posted Thu, 25 March 2004 at 6:21 AM
There was a bug in P3dO 1.6.5 with the Rsr2Png converter. Probably the PNGs have inverted channels. This bug has been fixed. To fix it you should have the lastest Rsr2Png 1.2.6, see the plugin version number in the about box. Here's the link for the fix: http://www.senosoft.com/downloads/C3DRsr2Png165126.zip Then run Rsr2Png and convert back to PNG, then run Rsr2Png again with fix blank PNG option, last convert the PNGs to RSR. Maybe is the fix blank PNG step not necessary, I'm not sure. btw You don't need to close the window to save a PNG as an RSR. Just save it as RSR. Sorry for the bug, I will double check if it occurs from the Edit Image menu. Yarp
Yarp - author of P3DO Organizer for Poser
garrr ( ) posted Thu, 25 March 2004 at 5:55 PM
Hi, i have done as you said, but it has not worked! nothing has changed and the rsr files ares till blank.
SentraZoe ( ) posted Thu, 25 March 2004 at 8:46 PM
Attached Link: http://www.renderosity.com/tut.ez?Form.ViewPages=193
Use SnowSultan's method on making .rsrs. His tutorial on it can be found here: http://www.renderosity.com/tut.ez?Form.ViewPages=193 Page 2 He has a lot of other useful tips, too. :) Hope that helps. :)
yarp ( ) posted Fri, 26 March 2004 at 1:09 AM
...or send me those pictures I will fix them - I just need the pictures not the MATs. This will help me understand why the fix doesn't work. my mail is yarp@senosoft.com
