Fri, Jan 24, 12:55 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 23 9:03 pm)
Subject: Camera memory dots
Jacqueline ( ) posted Sun, 28 March 2004 at 5:40 PM ยท edited Thu, 23 January 2025 at 9:15 PM
Hi Everyone, I have a quick question -if I have a PZ3 file with saved camera memory dots made in Poser 4 if someone uses the PZ3 in Poser 5 do the camera memory dots work too? Thanks, Jacqueline
lesbentley ( ) posted Sun, 28 March 2004 at 8:06 PM
Memory Dots do not save to a pz3. Memory Dots are saved to the path: [your Poser folder]RuntimeDOTS No pz3 contains information about Memory Dots. However the positions and other settings of all the cameras in the document at the time you saved the pz3, are stored in the pz3, so if you set up the cameras, people you send the pz3 to can use the camera menu to change to the Aux, Posing, and Dolly cameras, etc, and see what you saw through these cameras.
Little_Dragon ( ) posted Sun, 28 March 2004 at 8:35 PM
You can also save camera (.cm2) files to the Library, and then distribute those.
lesbentley ( ) posted Mon, 29 March 2004 at 12:03 PM
Also note that in Poser 4 the files associated with Camera Dots are in cm2 format, so you can copy or move them to a CAMERA sub-folder if you want.
