Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 15 9:11 am)
One, CC has a terrible Parent company, very poor customer service. Secondly if you bone something in Poser generated by Creature Creator use can not give it away as a freebie. Read the EULA. Two, I purchased CC as a LightWave plug-in several years ago, so yes you can refine the mesh in a modeler. Three, yes you could pose you little bottom off! You can import the exported object (depend on your Modeling App) into Poser. I suggest using UVMapper.
I have an old max plugin of CC. I never use it for anything but modeling and boning practice, but I generally have a good time when I mess around with it. I dont think CC is meant to be used as is, but as a starting point to refine or redefine the mesh. So, Kev, can the rat chase the cat if you should wish ? ~S
If that is an official statement of the Competition Rules, it seems that the objective is achievable. It's a style of figure I'm interested in, and which I've worked with. I'm familiar with the body of 2-D art on the theme. I would like to try. But, if the demo version is any guide at all, the prizes are not worth winning. The program uses a fixed-size window, which needs a monitor setting of 1280x1024, yet has a non-standard aspect ratio. It breaks many of the standard UI rules for Windows. It keeps missing mouse events. OK, so I doubt I would succeed at modifying the mesh this program can produce. "boning" is one of the dark and secret arts to me. But when I use the program of move or re-scale a part, and the mesh tears, it doesn't look right. Believe me, I have enough problems with bugs and misfeatures in Poser. I do not want to waste my time on another bug-ridden program. And, for the sort of anthropomorphic cat I want to use, I might as well start from Posette as from what Creature Creator produces. Yes, set a difficult target for a competition. But lets have a prixe that seems more worth the effort.
The mesh tears because it's a lo-res creature generator, I think; you are supposed to dense up and sculpt major parts of the mesh yoruself. If you want to give it a go, I suggest you try i.e gmax, wings, gamespace, maybe, or any of the other free modelers out there :-) also - I run on 1024 x 768, and CC seems to behave well. Now, anyway -it rebooted my system when I was doing stuff in Poser and Photoshop, but since poser was involved, I am not taking bets on which app caused the reboot ;-) tweaking the mesh is the fun part - I am sure you can leave out adding bones all together if you want ? ~S
hello ! I have some questions about Creature creator competition. 1: Can I bone the creature, or do I have to use creature as is generated in Creature Creator ? 2: Can I refine the mesh in a modeler - as long as the features are still recognisable and stick with the contest rules ? 3) I can pose it to my hearts content, as well as texture and UV map it, yes ? TIAV J.
