Mon, Dec 23, 8:34 PM CST
Subject: Haunted by a background photo
shorterbus ( ) posted Fri, 02 April 2004 at 1:10 AM · edited Mon, 23 December 2024 at 2:15 PM
Did a render with an improted background photo and now every time I try to render or enter material room Poser 5-4.321 looks (tirelessly) for that background picture. I've told it to stop searching and then saved as preferred launch state - no luck. Also, each time I start Poser it says my requested window too large, adjusting to next best thing. Also (deep breath) downloaded ISOP's french maid dress and each time I try to apply mat files the program freezes. Anyone got any clues. Thanks in advance.
TrekkieGrrrl ( ) posted Fri, 02 April 2004 at 1:27 AM
Do not set a preferred state. Set it to use Factory state, restart and THEN set your preferred state again. The "Window too large, creating the next best thing" is apprently a random error, at least I've had it happen from time to time in Poser 5, but no consistency. And Poser works fine after it has belched that error.
shorterbus ( ) posted Fri, 02 April 2004 at 1:37 AM
ernyoka1, thanks very much. BTW, figured out the ISOP problem.
msg24_7 ( ) posted Fri, 02 April 2004 at 3:26 AM
ernyoka1, the "Window too large" error is not a random error, as far as I can tell. It does happen when Poser crashes after you have used a background image larger than your current resolution, or have opened a .pz3 that was made by someone using a larger resolution than yours. Poser does save settings depending on your monitor resolution. The xml-files are somewhere in Runtime>prefs>ui if I remember correctly. Don't have Poser on this machine, so I can't check. As far as I can tell, it happens only when Poser crashes.
Yesterday's the past, tomorrow's the future, but today is a gift. That's why it's called the present.
lindans ( ) posted Fri, 02 April 2004 at 3:52 AM
Use poser with a higher screen resolution if it is set at 600 x 800 change it to 1024 x 768 you shouldn't have any probs then.
Oh, let the sun beat down upon my face. I am a traveler of both time and space ....Kashmir, Led Zeppelin
TrekkieGrrrl ( ) posted Fri, 02 April 2004 at 3:56 AM
Not always, msg.. I had it happen to me just the other day. I almostnever use background images, and this was just when I opened a new, BLANK document when it popped up and told me it was too large... You're right that the reasons you mentioned are USUALLY the cause. Just not allways L Poser IS weird!
catlin_mc ( ) posted Sat, 03 April 2004 at 11:03 AM
Mine is always telling me that my preferred state window is too large so I click ok and when it opens the window is there at the size I wanted. Go figure. 8P Catlin
