Sat, Feb 1, 4:45 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 01 3:31 pm)
Subject: I don't know if anybody can help me.I have a big problem with my poser 5.
kathymoon ( ) posted Sun, 04 April 2004 at 7:45 PM · edited Mon, 20 January 2025 at 7:53 AM
I don't know if anybody can help me, but i have problems with my poser 5. A few weeks ago the tools "Parameter Dials" don't show up. I have unistall and install the Poser more than 8 times and nothing happened. The Parameter Dials shows in Windows, but don't appears anywhere. Thank You....
texmextortilla ( ) posted Sun, 04 April 2004 at 8:07 PM
can't help ya, but i'll reply anyways.
PhilC ( ) posted Sun, 04 April 2004 at 9:26 PM
Mt first guess would be to try changing to a larger screen resolution.
EricofSD ( ) posted Sun, 04 April 2004 at 9:34 PM
I would think that the dials are there, just off the viewable screen. So using a higher resolution as PhilC suggests would help you find it. You can move them back into a viewable area and resize your screen, or, you might want to go to Edit-Preferences, and set to Factory State and see if that does it for you.
kathymoon ( ) posted Sun, 04 April 2004 at 9:52 PM
I try resize the screen,and edit preference and nothing. I search in all the corners and NOTHING! Im very sad.
mamba-negra ( ) posted Sun, 04 April 2004 at 10:00 PM
try double clicking on something. That will bring might open the small window (just a different tab)....it took me a little while to get used to that.. eric
ockham ( ) posted Sun, 04 April 2004 at 11:50 PM
Another thing you might try... No guarantee, but this sometimes helps with similar problems. Type po2 which will turn Poser into a more native Windows-style interface. Use the menu choice to turn on parameter dials. Move the dials into the middle of the screen. Now type po3 which will put back the usual Poser interface.
My python page
My ShareCG freebies
c1rcle ( ) posted Mon, 05 April 2004 at 2:44 AM
Did they leave that old chestnut in Poser5 ockham? kathy did you try to reset to factory settings under preferences?
c1rcle ( ) posted Mon, 05 April 2004 at 2:46 AM
aaargh gimme an edit button please :( have you installed the latest update this was a known problem in some of the earlier SR releases.
an0malaus ( ) posted Mon, 05 April 2004 at 9:03 AM
I've had P5 for a couple of weeks now. I run it on a G5 Mac with dual monitors and have been frustrated by the automatic relocation of the parameters window to be partially visible on the primary monitor every time I enter and exit the material room. I normally have the parameter window located completely on the second monitor. The relocation looks like an improperly implemented attempt to get around the problem of a completely inacessible off-screen window by moving it back into the viewport. I had run into that problem in P4 when one of my monitors was temporarily disconnected.
My ShareCG Stuff
Verbosity: Profusely promulgating Graham's number epics of complete and utter verbiage by the metric monkey barrel.
kathymoon ( ) posted Mon, 05 April 2004 at 11:58 AM
I already solve the problem. I need it to add the (upgrade)Poser5SR-4. What happend was that i was trying to add it a long time ago, but it was saying that it was invalid the zip. But today a friend downloaded and gave it to me. And that's the way i instaled it. Thank's everybody for the help!!!
TrekkieGrrrl ( ) posted Mon, 05 April 2004 at 12:51 PM
This may be a silly question, but what happens if you in the Window menu chose "Parameter dial"?
kathymoon ( ) posted Mon, 05 April 2004 at 1:03 PM
ernyoka (nothing happen if a choose de parameter dials in windows.) But i already solve the problem.Thank you.
TrekkieGrrrl ( ) posted Mon, 05 April 2004 at 1:19 PM
Sorry.. seems like it had been a while since I reloaded the page (I had been away from the computer L) Good to know you solved it :o)
