Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 09 2:22 am)
Attached Link: http://www.globetown.net/~kim99/tool/index_e.html
Hey EBob! Guess who finally rejoined ;P-> camelot:
You may find that Morph Manager 4 can't handle some of the newer character files, since it is no longer in development. If/when you run into this, you may want to try CR2Builder, which is updated regularly, the latest being in February of this year. Follow the link provided, and select version 02k.
waves Thanks for the link - I had seen CR2 builder, but I was a bit put off because there was no English documentation. It seems to be more based on John Stallings' CR2 Editor which I use a lot, and so far I haven't found anything that this or MM can't handle. That probably just means that I haven't tried anything V3 related. :) Both of these are general Poser file editors, which means they can transfer morph deltas as well as lots of other stuff. I'll give CR2 Builder a whirl next time I need to hack something. Morph Manager makes transferring morphs easy though; that's what it was designed for. When it can do it, that is. ;)
The download in the free section does'nt work, anyone know where I could get it? thanks in advance.
