First make sure that the black on your transmap is TRULY black! if it's just the slightest it non-black it will show up as ghosted. In Poser 4 I usuallyset bot trans min and Trans max to 100%, I'm not sure if you really need to set the trans min to 100 too, but I do to be sure. Falloff should be 0. Highlight should be black and so should the reflex unless you plug your transmap into the reflection too. If you want to save your square with a transmap applied, you save that square to the props palette. An easy way to make a png is to render a 91x91 version of your transmapped square and then save that to the palette with the same name as the pp2. (I am assuming you have Poser 4 Pro Pack sinnce you mention png, if you have Poser 4 you could then use P3DOExplorer to make the png into an rsr.
Thanks for you reply.Just one question.Do you make ground shadows with your alphas and if so how do you create them? I have been rendering my image with the Poser ground plane and deleting all but the shadows in Photoshop! But I seem to have problem with black alpha channel.Cheers arrow1
Custom built computer 128 gigs RAM,4 Terabyte hard drive, NVIDIA RTX 4060 TI 16 GIG Gig,12 TH Generation Intel i9, Dual LG Screens, 0/S Windows 11, networked to a Special 12th Generation intel I9, RTX 3060 12 Gig, Windows 11,64 gigs RAM, Dual Phillips Screens, 2 Terabyte SSD Hard Drive plus 1 Terabyte Hard Drive,3rd Computer intel i7,128 gigs ram, Graphics Card NVIDIA RTX 3060 Gig,1 Terabyte Hard Drive, OS Windows 11 64 Bit Dual Samsung Syncmaster 226bw Screens.Plus INFINITY Laptop 64 Bit,64 gigs RAM.Intel i9 chip.Windows 11 Pro and Ultimate. 4 x 2 Terrabyte Hard Drives and 2 x 2 Terrabyte external USB Hard drives. All Posers from 4 to Poser 2010 and 2012, 2014. Poser 11 and 12, 13, Hexagon 2.5 64 Bit, Carrara 8.5 Pro 64 bit, Adobe Photoshop CS4 Creative Production Suite. Adobe Photoshop CC 2024, Vue 10 and 10.5 Infinite Vue 11 14.5 Infinite plus Vue 15 and 16 Infinite, Vue 2023 and 2024, Plant Catologue, DAZ Studio 4.23, iClone 7 with 3DXchange and Character Creator 3, Nikon D3 Camera with several lenses. Nikon Z 6 ii and Z5. 180-600mm lens, 24-70 mm lens with adapter.Just added 2x 2 Terrabyte portable hard drives.
Can anyone give me a guide for render settings for Alpha Channels.I have made my texture and transparency map.I have then loaded the one sided square from the props library,but whatever settings I seem to apply I cannot get rid of the square when loaded into my scenes.What are the Highlight Size,Trans Min,Trans max and falloff? Also do I render Entire figure or highlight? I have reflection and bumps set to none and render through lights on.Do I save as a prop with nothing selected in the subset? And last question how do I get a png or rsr image showing in the library? Cheers arrow1
