Tue, Nov 26, 4:14 PM CST
Subject: Hawaiian Volcano?
ckeyes ( ) posted Wed, 14 April 2004 at 12:46 PM ยท edited Fri, 08 November 2024 at 4:43 AM
Hi,
Anyone know of a decent volcano scene or model
that could be used in V4 Pro?
I'm not to concerned out the lava eruption/flow.
I'll be comping that in After Effects.
Is there a way to get DEM's into V4?
Many thanks,
Carl
gebe ( ) posted Wed, 14 April 2004 at 1:04 PM
You can get DEMs into Vue. Read in the Handbook:-)
nanotyrannus ( ) posted Wed, 14 April 2004 at 1:27 PM
Attached Link: http://www.renderosity.com/gallery.ez?ByArtist=Yes&Artist=nanotyrannus
While Gebe is correct that you CAN get DEM's into Vue using the handbook, what the handbook doesn't tell you is that most DEM files have an edge along the sides that has "null" data, which causes a large wall to come up around the DEM you are importing. What I have done (see the link below for some finished examples of my method) is to use a third party program called 3dem to seamlessly combine multipart DEM's and then crop it down to the area I need (the area must be constrained to a roughly 4 quad by 4 quad area as Vue 4 will either not import or give you a flat plain for anything larger.) You then export the cropped area to a USGS DEM format and then import into Vue. Also, you will have to scale the resulting DEM (no matter which method you use) vertically by quite a bit, I have yet to figure out the exact conversion. Hope this helps :)
ckeyes ( ) posted Wed, 14 April 2004 at 2:11 PM
Thanks guys. I downloaded a map and it imported easily but the scale is way off, as expected. Pretty cool to be able to do though... Carl
forester ( ) posted Wed, 14 April 2004 at 3:10 PM
Online Now!
The normal scale for DEMs is about 1:3.
