That depends on what Poser version you have. Ockham has done a python script that mirrors a pose. But that requires Pro Pack or Poser 5 :o)
In SOME cases you can get by by simply using the Symmerty option in Poser, it really depends o the pose :o)
There is. First thing you do is choose "Symmetry" from the menu, and "Swap Left and Right" - once that's done, you'll have to manually change the Left and Right buttock bend, twist and side-side parameters (the symmetry button will not do this) and then change the side-side and twist parameters of Head, neck, chest and abdomen to the opposite of what they are (Negative if positive, Positive if negative). Finally, you may need to change the Zrot and Yrot parameters of the Hip or body to their opposites. Once that's all done, your pose will be 'flipped' and you may wish to save it to your pose library.
Attached Link: http://ockhamsbungalow.com/Python/SwapTotal.zip
Ockham has a pose swapping/flipping python script available, that has worked well for me.--------------------------------------------------------------------------------
Consider me insane if you wish, but is your reality any better?
I have a great pose from a package but I'd like it facing the other direction...is there an easy way to do this?
Visit My Blog!
