Thu, Jan 16, 3:50 AM CST
Subject: Bump Map Disaperas!
Ejaz ( ) posted Sat, 17 April 2004 at 6:31 PM ยท edited Thu, 16 January 2025 at 1:31 AM
I have modeled my aircraft in Rhino 3d and textured it using uv mapper.Then I exported the textured model as obj and imported in vue,all other textures were their with no problem but bump map disappers!!!can any one tell me the solution of this problem?Thanx for giving your time.
sittingblue ( ) posted Sun, 18 April 2004 at 3:01 AM
I can't say for sure without more information. What version of Vue are you using? Is the bump map loaded into the function editor?
One thing useful during imports is Poser 4 & 5. In some cases, Poser files import with fewer problems than .obj files. You could use Poser as a go-between.
Charles
SpringBirdy ( ) posted Mon, 19 April 2004 at 11:25 AM
"You could use Poser as a go-between" It's silly to assume that everybody has Poser or is willing to buy it to solve a problem with textures related to Rhino 3D don't you think?
