Mon, Nov 25, 10:52 AM CST
Subject: Broken wings - what the hell is causing this??
Lucy_Fur ( ) posted Sun, 18 April 2004 at 1:11 PM ยท edited Mon, 25 November 2024 at 10:33 AM
Working on an M3 (SR1) character and as you can see in the images, when his arms are raised, it looks very messed up.
For reference, here are the pertinent settings:
Body:
Tone - .5
Chest:
Pectoral - 1
Traps - .3
Lats -1
Serrs - 1
pExObliques - .6
Collars:
pPectoral - 1
pTraps - .3
pLats - 1
pSerrs - 1
Maybe someone can try those out & see if they come up w/the same problem I'm having. :(
Lucy_Fur ( ) posted Sun, 18 April 2004 at 1:12 PM
from the back
Lucy_Fur ( ) posted Sun, 18 April 2004 at 1:13 PM
different view
mesh
xoconostle ( ) posted Sun, 18 April 2004 at 1:29 PM
Have you also installed the updates for the body morphs? This looks like the problem many of us had before we knew that you had to install both the SR1 update and the muscle morphs update. I don't think it matters which order they're installed in, but you need both to cure this problem. If you have installed both, I have no idea what's causing this. Good luck!
las_61 ( ) posted Sun, 18 April 2004 at 3:10 PM
I don't know what's causing it, but I did try your settings and on the collars I used (-1) on the pLats small(on the right) instead of using (1)0n the pLats(on the left) dial it seemed to look better.
antioch ( ) posted Sun, 18 April 2004 at 11:38 PM
Sorry i can't offer any advice to fix the problem, however if you wanted to do a demonic figure someday that would look good. Almost as if something was trying to escape. (Aliens ??)
